Impossible de faire tourner mon F450 :( Besoin de votre aide
Oliv33
Message non lu par Oliv33 »
Salut salut
Voila envion 6 semaines que j'ai achété un F450 déjà monté avec un NAZA V2, j'ai ensuite pris un module FRsky X8R et une radio Taranis, tout a été branché mais je peine vraiment à tout paramétrer.
Les manches sont (pour moi) calibré mais j'ai toujours des messages d'erreur et bien sur mon F450 ne tourne pas :/
Voici ce que j'ai acctuellement:
Message d'erreur:
Motors Start failure caused by TX stick(s) mid point error too big
If the TX stick(s) mid point error is too big, Motors Start will fail when you execute the Combination Stick Commands (CSC)
and lead to the aircraft will not takeoff.. And the LED will blink Red four times per second continually to warn you.
TX stick(s) mid point error too big can be caused by the following reasons:
(1) There is TX stick (except the throttle stick) not at center when power on the autopilot system.
(2) The TX sticks has been trimmed, which leads to the large deviation of mid point. For example, the SUB-TRIM has been adjusted
for Futaba transmitter.
(3) The TX stick(s) travel has larger asymmetry.
For the reason (1), please put all TX sticks at the mid point, and then power cycle the autopilot system to re-record the mid point.
If the problem continues, that can be caused by the reason (2) or reason (3), you need to adjust the output range of your TX,
and then use the Assistant Software to redo the TX calibration. Please carry out the following procedures.
(1) Connect to the Assistant software, click Basic-> R/C-> Command Sticks Calibration, and push all TX sticks throughout their
complete travel range to see if any stick cannot reach its largest position.
(2) Adjust the largest travel of TX stick until the cursor on the Assistant software can reach both end positions, according to your TX manual.
(3) Power cycle the autopilot system, note that power cycle is required.
(4) Redo the TX calibration according to the Assistant software.
Je ne sais vraiment plus quoi faire et je tourne en rond :/
Par quoi RE commencer ? :/ que faire ?
Merci par avance :)
Oliv33
Re: Impossible de faire tourner mon F450 :( Besoin de votre
Je pense avoir un léger mieux.
En fait mon manche de Gaz (T) était inversé avec le manche (A).
Je suis allé dans les paramétre de ma radio et je l'ai passé en mode 3 et la les manches ce sont bien mis et je n'ai plus de message d'erreur.
Mais toujours pas de réaction du drone, la Led du V-SEN clignote rouge (lentement)
tu veux voler en quel mode, il faut le savoir pour être a ton aise, si tu as passé la radio en mode 3 c'est que tu n'avait pas bien branché tes fils en sortie de récepteur.
Oliv33
Je souhaite voler en mode 2.
Mais je ne comprend pas comment brancher les fils, car même si je ne branche pas de fils sur mon recepteur les manches bouge quand même sur mon logiciel NAZA. Dsl j'ai du mal à m'expliquer mais en gros j'aimerais invertir le T et le A sans toucher au mode en effet (je me suis remis sur le mode 3 sur la radio)
EDIT: la sortie du récepteur c'est M1 M2 M3 et M4 non ?
Sur le naza, M1 M2 etc, sont les sorties moteurs !!
Reprend la notice du naza http://f8byc1.free.fr/NoticeNAZA_V2FR.pdf" onclick="window.open(this.href);return false;
Regarde la aussi http://www.multi-rotor-fans-club.com/vi ... php?t=6376" onclick="window.open(this.href);return false;
Oliv33
Ok donc oui les M1 M2 M3 et M4 sont bien branché.
par contre je ne comprend vraiment pas pourquoi A et T sont inversé c'est fou !
dsl je débute vraiment :/
Tu es en Sbus d’après la photo poster, la c'est de la prog radio.
Vas voir aussi ICI
Oliv33
Merci poutr ton retour.
J'ai encore tout re verifier, je me suis mis en mode Tradition, j'ai re bindé le tout mais... toujours pareil :/
Guillaume22
Sur le menu de la taranis il faut que tu attribus tes voix même si tu la met en mode 2
Envoyé de mon iPad à l'aide de Tapatalk
Hexa quadrame naza v2
QAV400 naza lite
Pocket Naze 32
Twinstar APM 2.5
Doghfighter multiplex
Hélico Hurrican 550 CP
niarkniark33
Message non lu par niarkniark33 »
Oula, tu parts vraiment a zéro, sans aucune connaissance en modélisme et en radio.
Tu es motivés, mais il serait préférable que tu rapproches d'un club ou d'un magazin de modélisme qui pourront t'aider.
Ce forum est génial mais te lancer tout seul dans le multirotor sans aide, ça va être galère.
Futaba T7C + r617fs
GOPRO Héro2 + Ezosd
Ma chaine Youtube
Mon Topic
Oliv33
Guillaume22 a écrit :Sur le menu de la taranis il faut que tu attribus tes voix même si tu la met en mode 2
Yes nikel c'est fait :)
J'ai suivis ceci:
Dans "Mixeur" page 6/13
Tu vas sur "CH1" et tu clique avec "ENT"
Tu vas sur source que tu selectionne avec "ENT"
La source par defaut ("Dir" chez moi) clignote .
Tu bouge alors la fonction que tu veut attribuer a cette voie. Par exemple le stick de droite vers le haut ou vers le bas.
La source a alors changer, tu clique sur "exit" et est maintenant ton canal 1 est attibuer au manche de droite sens haut/bas.
niarkniark33 > Non je ne commence pas dans le modélisme... j'en ai fait pendent 10 ans (avion) et j'ai ensuite arrêté 3 ans et je me suis fait dépassé par pas mal de chose :/
EDIT: Je ne sais pas quel miracle mais j'ai réussi à faire tourner les moteur. J'ai allumé la radio, le drone, j'ai ensuite croisé les manches et les moteur ce sont allumé, par contre ça régie bizarrement, en fait quand je met les gaz les moteurs tournes mais par "palier" ce n'est pas "fluide" en gros j'ai que 3 niveau de vitesses, 1ére vitesse manche en bas, 2éme vitesse manche au milieu et 3éme vitesse à fond.
niarkniark33
Ah, je préfere :super: alors bonne continuation dans la programmation de la radio taranis, j'ai trouvé la notice en francais et j'ai déjà mal a la tete. :aille:
C'est une vrai usine cette radio! on peut la programmer dans tout les sens.
En plus nous n'habitons pas très loin l'un de l'autre.
Futaba T7C + r617fs
GOPRO Héro2 + Ezosd
Ma chaine Youtube
Mon Topic
